I got an old Tyrrell P34. The condition is not so good.
I will restorate it and I want to drive it on circuit. I will restore the tyrrell to win! Modification items 1. Change the motor RS-540 to the Tamiya Dynatech 02H. 2. Change the mechanical speed controller to ESC Novak 410 HPC. 3. Create body catch pins. 4. Restore the rear wing. 5. Get a new body. (Tamiya reproducted P34 body kit) 6. Get a new 7.2V short length battery (1700mAh) 7. Clean up the gears. Note: This is a secret project to my wife. |
Last edit: by CharAznable34. Reason: Typo
I look forward to the rest of this restoration.
the Tyrrell P34 is a very nice, and unique, model that is well worth taking care of. You are lucky to have one, and it even has the 540 motor conversion Quick Tip: To embed the attached pictures inside the post, click the "Insert" button to the right of the "Add File" and "Remove File" buttons, after selecting a file. Like this: -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
This is the Tamiya Dynatech 02H motor.
I also need to adjust this motor, because this is also old. This is the my favorite ESC NOVAK 410 HPC. I made two body catch pins. This is easy work... Fortunately, I got a body set. It is not new, but the condition is very good. Also, I got it with new decal. Body Kit Attachment not foundDecal Best regards, Char Aznable |
Wow, that poor P34 will get airborn with that Dunatech 02H motor!
Make sure to give enough down force on the new rear wing -Lars Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
The following user(s) Liked this: CharAznable34
