Thank you ! Well i didn't see any practice bumper on the instructions... so sorry but can't tell you if the car was sold with such a bumper. Yes, the shocks are fully operative, i just replaced the rear shocks fixing points as they weren't as they should be. Proud owner of the Bruiser Family
I want it... Lovely 959.
your the man fantastic top 959 one of the best out there great work
just to show u few pic from the manual the 2 screws that hold the bumper on they are hard to find new so i got my from tony uk ebay gets them in there the rear shocks u put the c1 parts on they are so easy to brake if u dont leave more then 1mm or 2mm on the thread they split down the middle that body is to die for tops on that mate and the light wire get tied down in the middle |
hi Manotas
see how u got the 3 wires for the resistor through the middle of the shocks in the book its on the out side but i think your idea better because you can tie it down with the head lights wires had to point that out if u want to make your msc newer just buy a new msc thats the same middle part then u unsolder all the wires then just place the wires on another msc you can change out the plugs too um when u take off all the wires the motor wires the outer cover just put new ones on there to make it new again as for the tamiya plug when u look down the plug there 2 main circle pins there's 2 littler pins that come off the center that hold it place just use a very small flat head put the screwdriver down the side of it then turn the screwdriver a little bit it will then push the pins back the white plug will come off use a needle to pull the pins out again and then put another new plastic part on then u will have a newer msc for less the half the money as a new porsche 959 one |
Last edit: by spannerman3.
What a lovely pair Manotas Really nice work, Will you be custom building a set of race trailers to display them behind a couple of the Bruiser Family If you can't fix it with a hammer, you've got an electrical problem mate
Last edit: by AndyAus.
Bumps in the roof?
