Terra scorcher pinion position 4 years 4 months ago #57699
Hi can any tell me the thickness of the g part used to position the pinion on the terra scorcher or how far the pinion is form the motor as I don’t have this part to set up the pinion
Terra scorcher pinion position 4 years 4 months ago #57703
Hi there, I don't have one of those pinion setting parts only a Hot Shot version. It doesn't have the raised top on it but I can tell you it is 7mm high and 2mm thick. Usually when I have to set he pinion on the motor and cannot see the meshing, I use and small ruler to measure form the far side if the gear to the gearbox housing where the motor mounts and go from there.
Last edit: by AndyAus.
Terra scorcher pinion position 4 years 4 months ago #57704
Sorry Andy. I haven't this part.
Time to create page: 0.156 seconds
