Re: Tamiya Avante 2001 QD, using a different remote 11 years 11 months ago #10162
this is pretty much how the insides of the first QDs looks like.
yeah thats what an avante qd looks like
Re: Tamiya Avante 2001 QD, using a different remote 11 years 11 months ago #10163
well if that bit aint working throw it out with the servo, and get an esc that works with the 380 motor, a servo and a receiver. A standard servo will fit nicely after you cut of the side thingies and you might want to put something underneath it (the original is a little higher)
I got mine an used micro losi esc, so it even got dragbrake now :lol: (see my first post)
Re: Tamiya Avante 2001 QD, using a different remote 11 years 11 months ago #10164
So, IF you were up to it & had the inclination, we reckon the 5-wire QD steering servo could be made to work with a proper Rx if you routed it through a spare servo board. In summary, it would look like "QD servo >> proper servo board >> proper Rx".
If you attempt it, things you'll need to be ready for:
Pull the QD servo apart to see what colour wire is connected to what - you need to know motor +, motor -, pot centre, pot left, pot right.
On your substitution servo board, you'll need to know where those wires need to be connected, so take pics, draw diagrams etc BEFORE you cut the wires from the board.
The substitute board needs to be one that operates a similar size motor to the one in the QD servo. AND ideally the pots in the QD & proper servos need to have similar resistive values (Ohms), measure the whole end-to-end value, the values for centre-to-end for both ends, at rest & at full left/right positions - if they're a lot different to the pot in the substitute servo, it can affect the amount of steering you'll get or possibly confuse the new servo board. You could also consider swapping the pots over if they're physically the same but different values.
It's likely you won't get the pot or motor wiring the right way around first try, so;
If the servo works in reverse (Left-stick gives right-steering) & using the reversing switch on the new transmitter doesn't sort it (Or it hasn't got reversing switches), you need to swap the motor connections AND swap the end connections to the pot.
If the servo turns to full scale & hums or gets warm, you need to swap just the end connections on the pot. If that doesn't sort it, swap the pot wires back & swap the motor wires instead.
Be prepared to spend a whole day messing about with it & have to give up, as with this "Trial & error" method, there's only a 50% chance it'll work & less that it'll work perfectly
Re: Tamiya Avante 2001 QD, using a different remote 11 years 11 months ago #10165
Ha, I clearly took too long writing that & Waterbok's come up with a much more sensible solution!
Well, it's written now, just in case someone else fancies a bit of amateur electronics!
Time to create page: 0.116 seconds
