CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 10 months ago #44637
That is nice engineering, Jonny! :y:
Seems to have been an awful lot of faffing about to get to this point on the water cannon ...
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 10 months ago #44654
This needs headlamps, I had a spare Frog type pair & they seemed about the right size ... I haven't really thought of a better way of converting them to actual lights since I modified some for my DT-02 Grasshopper so I used the same method - hollow out, fit LED & backfill with Milliput:
Really wans't feeling the grille as drawn from my photos of the Corgi diecast (not sure where to start on the chunky flat pattern as much as anything) so worked instead from the curvier rad found in a lot of online sources ... 58 fiddly parts later I felt I made a reasonable job of it, but it just didn't look right once I'd bonded it on...
... almost by chance I found a post from someone complaining that the Italieri 1:43 kit of the Morris Quad (which looks almost identical to the Corgi Quad Tractor) isn't a Morris at all - further sources tend to confirm it is in fact a CMP (Canadian Military Pattern) Truck, specifically a FAT-2 built by Ford :whistle:
This did lead to some much better grille photos though, and a way to procede - basic backing/frame, a bit of boxing on top & the rest is 2mm woven steel mesh with a bit of artful cutting & bending - now I can see what Corgi were trying to replicate & it looks a lot better on my model :)
I didn't want to waste the Morris type grille though - so added an Austin badge (too big, but it's as small as I could manage to hand cut) ... after a bit of paint it won't look out of place in my scale garage :)
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 10 months ago #44660
Amazing. And I love your grille.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 9 months ago #44725
Still need to cut out "glass" + make wipers & mirrors, but that's all the details on the front done ...
... however ... I'm not sure what my reasoning was for abbreviating the sides of the hood/engine bay from 6 bits per side to 3, but I've become increasingly dissatisfied with it looking wrong - the only way to fix it is to cut it all out & remodel it. Still needs the other side doing,plus filling & blending, but I'm already happier with it :)
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 9 months ago #44731
Where is the matter???? There are a lot of amazing details, it looks aweome. Maybe you started with a bad idea of this project??? It is very nice.
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 9 months ago #44781
Happier with the more correct front end, even made a little progress (wipers & "glass") :)
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 9 months ago #44782
:woohoo: :y:
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 9 months ago #44823
External details done, plus internal rear wheelarches - a bit narrow but they need to fit over the tank & chassis sides ...
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 9 months ago #44824
WAHOOOOOOOOO what the work! too nice!
CC-01s: RV, Unimog, Bedford TM, Valp, Ford CMP, Series 3 Land Rover, SD Revopak 6 years 9 months ago #44825
I second that!! Jonny that this is one of the coolest builds I have seen in a long time. Your work is excellent as always....
Time to create page: 0.346 seconds
