1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31877
....and he's back on it again :woohoo:
I love watching you make this stuff Jonny!
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31881
How about plastic drain pipe or something for the tank?
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31882
I did look into that, but the cost, wall thickness & being a different plastic (so potentially issues with joining it) put me right off ...
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31883
I knew there was a good reason why I should make the baffles ring shaped rather than solid, but it escaped me, so I left them solid ... then realised if they were rings, it would make fixing the skin on so much easier if I could put the DCM on from the inside.
Due to the angle it doesn't look it, but this is the centre - measure diameter (142mm), set compass to 1/2 that, run two arcs from the edge & where they cross is the centre, 3rd is just to check.
After a lot of dremelling (I didn't need access through the centre baffle, so left it alone) & gluing the 1st later of 0.5mm sheet:
That did leave the outside surface a bit wobbly, but a 2nd layer smoothed things out considerably:
Cutting through the 1st layer for the wheel insets:
Bonding the two layers around the openings:
2nd layer cut through:
Wheelarches/liners are setting ATM, I've also been giving the ends of the tank some thought ... they ought to be dome shaped, I'll have a look around & if I can find something the right profile there are a few options (crash forming, casting, vacuum forming), if not they'll have to just be flat bits of sheet.
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31912
I decided to do the tank ends flat in the end ... not ruling out making a vacformer at some point in the future, just not yet ... besides which, you need to have something to form over, and if I could make a shallow dome I wouldn't need to vacform it :whistle: I did look at getting a few different size clock glasses & taking a cast off the inside, but it's a look of expense & faffing about I can avoid by just doing them flat...
Mudguards are a bit of a compromise, thin enough to take the right arc means they're too thin to hold a 90 degree edge...
... I did have the cunning plan of taping the edges at the right angle & then heating it to relax the plastic, but you can see how well that worked:
Not a pregnancy test stick for elephants, this is the start of the drawbar (very abbreviated chassis):
Axle is made from layers of styrene, some drilled 10mm for bearings, most just 5mm here:
I had to hoover myself too :whistle:
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31919
Good work JR :)
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31933
Basic construction done - it's "just" details & paint from here on...
Tank pivots around axle at the rear & is sprung at the front a la 1:1 tanker, spring seats are de-chromed & cut down Lunchbox shock bodies. Angle is a bit much at 7 degrees vs the models' 5 degree tilt, either this will decrease as the weight increases or I'll have to find shorter/softer springs; tow hitch is a bit of a lash up but may not improve that much :whistle:
I'm reasonably happy with the size, there's some bits to hang off the rear & increase the height a bit so the proportions will change (improve IMO) as this goes on, but I'm quite clear that the twice as long/twice the diameter dimensions of the tank that a "correct" build would have required would have been silly :)
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31936
HI JR,
This is looking good, but have you tested with a wider wheelbase?
To me, the wheelbase looks a bit on the narrow side.
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31937
It's 226mm wide, in proportion with the rest of the tanker - it's the tractor that's "wrong" :)
1979 Fiat Trattori 880 DT Pininfarina build 9 years 6 months ago #31938
Ah, ok. Still, for the pair, I think a wider wheelbase would suit it ;)
Time to create page: 0.322 seconds
