HI!... I'm in need of some (X2) of some 3MM Tamiya Well nuts. Anyone got some they want to get rid of or sell. I need two ASAP.
Thanks : Neal |
Last edit: by larbut. Reason: moved to "wanted" section.
I haven't looked recently, but they used to be available from RS components (rswww.com), I can't remember what they called them either, but it wasn't well-nuts (Have a wander around their website in the fixtures/fittings section).
A trick if you get stuck - use soft rubber tubes, bore size just big enough to take an M3 flange-nut hex - stuff the hex into the tubing, the flange stops it disappearing up the hole when you tighten it. The rubber needs to be just soft enough that it will swell when tightening, but not let the nut flange pass through it. Normal grommits (With a nut+bolt through) can work too in some cases, if you're not concerned with originality (eg SRB radio box)
HI!... Thanks Waterbok I did a well nut search on Ebay before I posted this thread and that sale never showed up. lol! I actually need these for my Renault 5 Turbo restoration. I have one new well nut. I just needed two more for between the chassis and the aluminum battery tray. The originals were all dry rotted and falling apart.
