Non bec receiver+ "modern" ESC 4 years 1 week ago #59617
Hi guys,
I have a question to avoid to toast my old sanwa gc3300 rx I puted on my mountaineer.
I puted a period esc a futaba mc112 in place of a msc.
The gc hasn't a bec system. So I used a 4cells clip. But the system works without the clip. Like if the esc gives power to the receiver. Is it dangerous for the receiver? Should I keep the cells clip or not? Is there a risk to toast the receiver with the esc?
I took a 10 minutes run without matter nor burning smell.
Thanks for your advices.
Flo
Non bec receiver+ "modern" ESC 4 years 1 week ago #59618
Hi guys,
Flo
What's the output on the +ve (& -ve) from the ESC? A multimeter ought to be part of everyone's tool kit, even a 5 EUR analogue model.
I don't believe there is a standard as such, but the Tamiya TEU101BK outputs whatever the drive battery is outputting (so up to 11v+ for a freshly charged NiMH pack :blink:), but every other ESC I've ever measured IIRC was 4.8v. I think i';ve read about 6v DV outputs, but to get that you'd usually need a UBEC with a switchable outputs.
I wouldn't count on being safe, you'll think it's fine right up until the magic smoke escapes ;)
Non bec receiver+ "modern" ESC 4 years 1 week ago #59619
Thanks Jonny. I will control all that.
Non bec receiver+ "modern" ESC 4 years 1 week ago #59620
please take note the old sanwa are wired different too the servo wire
from the futaba
Last edit: by spannerman3.
Non bec receiver+ "modern" ESC 4 years 1 week ago #59622
Here is the temporary original setup. With the clip
Cells clip, switch and receiver. For the servos, steering to channel 1, esc to channel 2 always on switched and gearbox to channel 3.
Non bec receiver+ "modern" ESC 4 years 6 days ago #59695
hi yes u can use a new esc on the 2200 receiver so i guessing u can do this all so to the 3300
have a look
if i was u i would be getting a broken servo from the 3300 then take the wire off
the servo
then buy a female futaba plug then put the plug onto the end
so the the esc will into it
Non bec receiver+ "modern" ESC 4 years 6 days ago #59696
sorry if your thinking why is there only one plug in the receiver
1 for the servo
and the esc is hard wired in
and if anyone got a spare 2200 receiver bottom please email cuz i had to brake it to get it off PLEASE
one of the screws were rust bad
works great
Non bec receiver+ "modern" ESC 4 years 5 days ago #59698
Thanks spannerman. Modern connectors fit on the 3300. Naturally with the + on the right side. ;)
Sorry I sold a 2200 last year.
Non bec receiver+ "modern" ESC 4 years 4 days ago #59734
hi stingray-63 would u know the question
the
Turnigy 1000mAh 2S 30C 7.4v Lipo Pack Battery XT60 JST-XH
i have a battery charger iMAX B6
what do u charge this at
lipo 7.4 2c 500mah that right? balance charge
i just want to make sure
Non bec receiver+ "modern" ESC 4 years 4 days ago #59740
No lipo charging is generally 1c. So, your stick is 1000mAh 2S you have to trim the b6 on 2S at 1000mAh (1A) and plug the balancing wire.
Time to create page: 0.180 seconds
