It's tool time! 9 years 11 months ago #28717
As far as I can see, the angle depend on what type of screw.
The "Google consensus" seem to be 82 degrees for US threads, and 90 degree for metric screws.
It's tool time! 9 years 11 months ago #28721
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
I'll go for the perpendicular version then. :y:
The one in my toolbox seems to have a smaller angle...
And checking a random Tamiya screw, it indeed looks 90 degrees.
Diameter isn't much of an issue I think, maybe just for a bit of precision, as it simply depends on how deep you drill.
A long as it's bigger than the screw head.
It's tool time! 9 years 11 months ago #28722
It's tool time! 9 years 11 months ago #28724
  • Edou
  • Hopping Mad
  • Hopping Mad
I found some nice parts here and there using the term countersink instead of countersunk...
Hadn't thought of it for this yet.
:y:
It's tool time! 9 years 11 months ago #28725
once you countersink the hole with the appropriate tool it is countersunk. :whistle:
:laugh: :laugh:
It's tool time! 9 years 11 months ago #28726
  • Edou
  • Hopping Mad
  • Hopping Mad
Our Chinese friends are not always aware of the tense of a verb.
Countersink washers would imply you have to make 'em like that yourself...
As if they didn't countersank them for you.
:silly:
It's tool time! 9 years 11 months ago #28727
  • Edou
  • Hopping Mad
  • Hopping Mad
While I'm at it - best size for battery pack heat shrink... 60mm?
Messed up my best one. Thought there was loads of room in a Grasshopper but yanked the wiring.
:S
On topic - I have a heat gun for that, lol.
Edit - think the last batch I had was 65mm. Seems a bit better. Advice is welcome though!
It's tool time! 9 years 11 months ago #28728
depends on the size of the stickpack but think we are talking standard 7.2 stick with 6 cells right.
I use 69mm that work out fine
It's tool time! 9 years 11 months ago #28729
  • Edou
  • Hopping Mad
  • Hopping Mad
Let me rebuild that LRP 5Ah then... rather strange how the silicone wire casing tore at the base.
Think I may leave the caps off - then it'll fit a lot easier on a variety of older chassis.
It's tool time! 9 years 11 months ago #28730
:S
Edou if you want, I have black heat shrink wich is nice for sticks. I can send you a band. ;)
Time to create page: 0.174 seconds
