It's tool time! 9 years 11 months ago #28735
  • Edou
  • Edou's Avatar Topic Author
  • Hopping Mad
  • Hopping Mad
That would be great! :)
It's tool time! 9 years 11 months ago #28738
  • Edou
  • Hopping Mad
  • Hopping Mad
Did an okay fix for now. :)
Just has slightly shorter wiring (and some isolation tape)...
One thing I don't understand is why the LRP solder needs about a million degrees to melt. :blink:
Couldn't really get it done! Added some of my own (not too much for thickness) and finally got that finished.
One thing you don't want to do is keep the soldering iron on the pack for an extended period of time (so I avoided that).
It's tool time! 9 years 11 months ago #28740
Check out the chart on ebay listing 140881294705, "CS" column, 4th row (2 cells side by side) - this suggests 83mm wide (lay flat width) is ideal ... the seller didn't have that so I bought 108mm, which was still fine ... I see the seller is now out of that so I appreciate that this post is of limited use :whistle: ... this PVC heatshrink is better than I've used before though, it's thinner wall & is thinner, harder & smoother in use, so fits car apertures better :)
It's tool time! 9 years 11 months ago #28747
83 is indeed for sideby side, stickpack is 67 though B)
It's tool time! 9 years 11 months ago #28748
Mine are 83mm and nice adjusted on my sticks after heated
It's tool time! 9 years 11 months ago #28754
  • Edou
  • Hopping Mad
  • Hopping Mad
Great table in that eBay ad. :y:
As long as the tube is tight after heating, I guess any size goes.
Only consideration would be to take it a bit slower with the bigger ones, as to not overheat the cells...
Thanks, guys!
It's tool time! 9 years 11 months ago #28762
;) You have the time for overheat the cells. Just the time to reduce the shrink. 350°C is faster than a hair dryer.
It's tool time! 9 years 11 months ago #28763
:) very good surprise! an electric screw driver for 19,90€ from LIDL. better than a bosch wich costs 70€.
All the lidl Tools are a very good quality.
And my unseparable facom radio box.
It's tool time! 9 years 11 months ago #28767
  • Edou
  • Hopping Mad
  • Hopping Mad
They have some great stuff - I am often tempted by it as well. :y:
It's tool time! 9 years 11 months ago #28784
;) You can buy closed eyes. screw drivers and "pinces" are very efficients
Time to create page: 0.211 seconds
