58500 revealed by Tamiya!!!! 12 years 9 months ago #1870
And it's the Sand Rover on the Horror Buggy reissue DT02 chassis. :sick:
And some was VERY certain the 58500 should be a reissue Egress... :lol:
These are the specs from Tamiyausa.com:
The Sand Rover attracted many hobbyists to the exciting world of R/C in the early days of the radio control buggy era. Originally released in 1981, the R/C Sand Rover featured simple construction and a dune buggy body design. To celebrate its 30th anniversary, Tamiya is matching the classic buggy body with the modern, easy-to-assemble DT-02 chassis, making it perfect for those who are new to R/C hobby.
Specs and Features
1/10 scale R/C assembly kit.
Kit includes FREE BONUS PARTS (1150 Ball Bearing x 8pcs.) First production run bonus only. 10/2011
The durable resin body is molded in white and may be finished using Tamiya Color paints.
The DT-02 chassis is equipped with a 4-wheel independent suspension with coil spring dampers.
380 size motor included and is coupled with a 10T pinion gear (gear ratio=15.768:1)
Fully-enclosed gearbox protects against dirt and debris.
Ribbed front and spiked rear tires
Semi-finished driver figure (pre-painted face & hat) included.
Included Type 380 motor can be replaced with Type 540 motor to increase speed and power.
Tamiya TEU-104BK forward and reverse brushed motor speed control. (equipped with low voltage protection feature)
-Lars
Last edit: by larbut.
Re: 58500 revealed by Tamiya!!!! 12 years 9 months ago #1876
That kind of sucks. I was expecting more for #500... :(
Re: 58500 revealed by Tamiya!!!! 12 years 9 months ago #1883
I'm actually quite positive about this one - it probably means lots of cheap body sets for - 1/ "restoring" vintage Sand Rovers;
2/ lots of rough old vintage Holiday Buggys getting a new lease of life;
3/ fitting to re-re SRB chassis & having a good looking, capable (albeit expensive) chassis under the shell :D
Shame there won't be any of the original rear knobblie tyres though :(
Re: 58500 revealed by Tamiya!!!! 12 years 9 months ago #1885
The car itself could be lots of fun of course. :cheer:
But for this number I was expecting something special...
Re: 58500 revealed by Tamiya!!!! 12 years 9 months ago #1890
We can hope for the body to be like the original, but I fear this one also will get "vent holes" in the bonnet/hood to make room for the DT-02 damper towers.
-Lars
Re: 58500 revealed by Tamiya!!!! 12 years 9 months ago #1891
-Lars
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!
Although you're probably right :(
Re: 58500 revealed by Tamiya!!!! 12 years 9 months ago #1922
The more I think about it, the cooler these new releases become.
Unfortunately that counts the least for this special number.
I would have loved to have seen a (evolved) full option Top Force Evo II.
Mostly complying with the original parts with some new upgrades - maybe a slipper clutch for example.
And a whole new range or releases for the parts.
Then it would be much more memorable or almost legendary like the 58100 is. :)
Time to create page: 0.131 seconds
