My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10592
On to actual building - page 3, steering rods/servo saver & front arms:
Page 4 - rest of the front end:
I think ther must be a "mk.1" and "mk.2" LWB Willy - the two Willys I have both have some differences to the manual - firstly wjere the "pipe holders" fasten on to the front strut tops (J6): in the manual the screws go in to blind holes from underneath; but on my cars the screws go through the strut tops & into threaded holes in the holders:
I can't do page 5 (yet) due to not having the switch plate :(
Page 6 - attaching motor, motor base & diff gear case. More differences here, the manual calls for M4 screws going in the underside of the ally plates & being held on the chassis by nuts; on my cars, M3 screws go in from the top of the chassis into tapped holes in the motor base plates:
Page 7 - diff case & rear arms:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10593
Yes the manual you got is for the Mk.1 SWB hence the differences. the LWB manual you can find at Tamiyabase.com :woohoo:
*badword* is that Willy shinny. B)
Are those fasteners stainless and I saw the brass bearings, no ballbearing upgrade?
did you use the small brass tube h8 on the steering rod and chassis tub
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10594
Yes the manual you got is for the Mk.1 SWB hence the differences. the LWB manual you can find at Tamiyabase.com :woohoo: ...
I probably should have noticed the round holes in the Arm Stays :whistle:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10595
If possible, email me jpg scans (150 dpi) of that SWB Willy manual, and I will put it up here. :)
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10596
I think the TamiyaClub.com watermarks might be a problem :whistle:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10597
Correct, that would be a problem :laugh:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10603
Oops :blush: didn't some one I personaly know, offer to scan his SWB manual :S
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10604
I got a pretty good scan, without any watermarks as well... :y:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10606
Just about finished the building ... step by step photos went out the window as the build order is completely different with the LWB manual (and makes a lot more sense in some ways) ... pinion is not ideal but is better than the "correct" one I had ...
Cat was determined to "investigate" the small parts:
I'm missing one of the top hat washers from the bottom of one of the rear shocks, there's no electrics in there, and the mechanism box lid could stand some repairs, but for now, apart from possibly a bit of lettering on the body, I'm going to call this "done" :)
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 9 months ago #10610
Excellent build and great colour. Bling indeed. :) :y:
Time to create page: 0.185 seconds
