Baja's VDF build 12 years 1 month ago #8526
I'm sure almost everyone has seen this build since i've posted it almost everywhere :laugh:
Anyway,I found this site while looking for info on a up coming dream build of mine a SS.
So on to the build.
What a great sight
Warp off
Open!!! :D
build started
blukheads on :)
steal some more parts from the R :P
bag B
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8527
bag C
steal a few more parts from the R :P
now has arms :D ( missed a bit of bag C because i have to charge the camera )
all arms done
bag D
drive train fully in now i way also playing with the steering as well :P
it's build some TRFs time :D
BLUE!
rebuild the sevro
REC in the center
and here it is one god like drifter still needs my hop ups but they should be here soon.Thanks for looking.
Make:Tamiya
Model:TA05 VDF blue
Track surface: Monash
Tire:ABS soon to be T drifts
Motor & ESC:Yeah Racing 13t combo soon to be SP stuff
Front
Camber:-1
Toe:in 3
Kick up:3mm
Caster hubs:4deg
Ride height:5mm
Springs:HPI yellow
Bumper weight:0
Sway-Bar:N/A
Shock Oil:20.000wt losi diff oil
Rear
Camber:0
Toe:in 1
Kick up:0
Ride height:4mm
Springs: tamiya red painted black for looks :P
Sway-Bar:N/A
Shock Oil:15wt losi
Drive Train
Front:36
Front Center:18
Rear Center:22
Rear:30
Over drive: 46% ( mite go up more )
Spur:128
Pinion:39
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8528
goodies :D
new tires and rims it's so much faster now :)
re drilled arms so i can get more angle without hitting the shocks
getting close to the bumper and as you can see no were near the shock :)
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8529
Soarer done :) the paint is bassed off Matt Power's S14
my fav shot
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8530
BLUE! with the 2 golds :D ( sorry for desk light fail :( )
Better pic of the 2 golds :)
Gold!
open looks the same
we found GOLD!!!
mmmmmmm GOLD!
one gold is to shelf and the other is for spare parts.
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8531
GOLD!!!
can't run a foam bumper tho kinda a shame but not a big problem
mounted
moded the diffuser pulled it up about 5mm makes it look so much better was
going to make my own but this was the easy way out :P
you can see were its cut and pulled up here better
If you want to know what paint i used ( PM me to know how i do it )
nice clean sharp line i did good :D
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8532
I got a almost new blue of a friend for a good price.i will be using it so rebuild time :) WARNING: if you don't like dirty cars look away now :P
very vile diff :coke: :puke:
almost fully apart
and done ( yes i have fixed the bad toe out now )
beside other blue B)
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8533
Ok got some new pics
First is the OTA VDF aka VDF 1
huge 23 center pully
nice angle
nice and shiny :) but the rear is a bit beat up
now for the camaro ( still not fully done yet )
you sure you want to see it
really?
It looks just so mean B)
Make:Tamiya
Model:TA05 VDF
Tire: T drifts
Motor & ESC: Hobby Wing 9t combo
Front
Camber:-6
Toe:in 1
Kick up:3mm
Caster hubs:7
Ride height:6mm
Springs:Tamiya Yellow
Bumper weight:TB03 ally bumper brace
Trailing Steering Block:OTA
Sway-Bar:N/A
Shock Oil:150wt
Other:front has a OTA sus set the rear is stock
Rear
Camber:0
Toe:0
Kick up:1mm
Ride height:14mm ( with out battery with battery its 8mm )
Springs: stock CC01
Sway-Bar:N/A
Shock Oil:35wt
Drive Train
Front:36
Front Center:16
Rear Center:23
Rear:30
Spur:128
Pinion:39
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8534
Now the VDF ( now VDF 2 ) i built in this thread
nice angle not as much as VDF 1 but good :)
Soarer bit beat up now
10goku :P
battle scars
Track surface:monash
Tire:t drifts
Motor & ESC: Yeah recing 13t combo
Front
Camber:-1
Toe:0
Kick up:0
Caster hubs:stock
Ride height:6mm
Springs:don't know but they are quite hard
Bumper weight:0
Trailing Steering Block:stock
Sway-Bar:N/A
Shock Oil:100wt
Rear
Camber:0
Toe:1
Kick up:2mm
Ride height:7mm
Springs:stock
Sway-Bar:N/A
Shock Oil:35wt
Drive Train
Front:37
Front Center:16
Rear Center:22
Rear:32
Spur:120
Pinion:39
Team Bad Attitude
Re: Baja's VDF build 12 years 1 month ago #8535
New project a AE86 levin drift pig :)
filled the old body holes with a little CA glue
glued some scarp lexan under the old holes
hot glued the hood to the front end
looking good :)
hood painted :)
done :D
lota lock :kingthumbsup:
bit of rust
can't even tell there there were body holes there before :)
made a real wiper its better then a badword sticker
Team Bad Attitude
Time to create page: 0.496 seconds
