bag C steal a few more parts from the R now has arms ( missed a bit of bag C because i have to charge the camera ) all arms done bag D drive train fully in now i way also playing with the steering as well it's build some TRFs time BLUE! rebuild the sevro REC in the center and here it is one god like drifter still needs my hop ups but they should be here soon.Thanks for looking. Make:Tamiya Model:TA05 VDF blue Track surface: Monash Tire:ABS soon to be T drifts Motor & ESC:Yeah Racing 13t combo soon to be SP stuff Front Camber:-1 Toe:in 3 Kick up:3mm Caster hubs:4deg Ride height:5mm Springs:HPI yellow Bumper weight:0 Sway-Bar:N/A Shock Oil:20.000wt losi diff oil Rear Camber:0 Toe:in 1 Kick up:0 Ride height:4mm Springs: tamiya red painted black for looks Sway-Bar:N/A Shock Oil:15wt losi Drive Train Front:36 Front Center:18 Rear Center:22 Rear:30 Over drive: 46% ( mite go up more ) Spur:128 Pinion:39 Team Bad Attitude
GOLD!!! can't run a foam bumper tho kinda a shame but not a big problem mounted moded the diffuser pulled it up about 5mm makes it look so much better was going to make my own but this was the easy way out you can see were its cut and pulled up here better If you want to know what paint i used ( PM me to know how i do it ) nice clean sharp line i did good Team Bad Attitude
Ok got some new pics
First is the OTA VDF aka VDF 1 huge 23 center pully nice angle nice and shiny but the rear is a bit beat up now for the camaro ( still not fully done yet ) you sure you want to see it really? It looks just so mean Make:Tamiya Model:TA05 VDF Track surface: Monash Tire: T drifts Motor & ESC: Hobby Wing 9t combo Front Camber:-6 Toe:in 1 Kick up:3mm Caster hubs:7 Ride height:6mm Springs:Tamiya Yellow Bumper weight:TB03 ally bumper brace Trailing Steering Block:OTA Sway-Bar:N/A Shock Oil:150wt Other:front has a OTA sus set the rear is stock Rear Camber:0 Toe:0 Kick up:1mm Ride height:14mm ( with out battery with battery its 8mm ) Springs: stock CC01 Sway-Bar:N/A Shock Oil:35wt Drive Train Front:36 Front Center:16 Rear Center:23 Rear:30 Spur:128 Pinion:39 Team Bad Attitude
Now the VDF ( now VDF 2 ) i built in this thread
nice angle not as much as VDF 1 but good Soarer bit beat up now 10goku battle scars Track surface:monash Tire:t drifts Motor & ESC: Yeah recing 13t combo Front Camber:-1 Toe:0 Kick up:0 Caster hubs:stock Ride height:6mm Springs:don't know but they are quite hard Bumper weight:0 Trailing Steering Block:stock Sway-Bar:N/A Shock Oil:100wt Rear Camber:0 Toe:1 Kick up:2mm Ride height:7mm Springs:stock Sway-Bar:N/A Shock Oil:35wt Drive Train Front:37 Front Center:16 Rear Center:22 Rear:32 Spur:120 Pinion:39 Team Bad Attitude
New project a AE86 levin drift pig filled the old body holes with a little CA glue glued some scarp lexan under the old holes hot glued the hood to the front end looking good hood painted done lota lock :kingthumbsup: bit of rust can't even tell there there were body holes there before made a real wiper its better then a badword sticker Team Bad Attitude
