My M chassis builds 2 years 5 months ago #69469
Number plates – it’s a plausible local combination for 1971, but not currently extant AFAIK. I could go into detail but it’s very dull – read www.cvpg.co.uk/REG.pdf if you really care ;)
The following user(s) Liked this: caprinut, stingray-63, silvertriple, jord001
My M chassis builds 2 years 5 months ago #69470
I like theme.
My M chassis builds 2 years 5 months ago #69473
I like the nsu it make le think to the r8 and r10 and the simca 1000.
My M chassis builds 2 years 5 months ago #69485
Wheels - I removed the outermost lip & square off the two flats & vertical between them on the Unimat, then add two layers of 0.5mm styrene. This makes them a scale 14", rather than the stock 15.75" (the scale 12" I got when using this type of wheel for "Snowy" would have been too much).
I will trim off the excess once everything is set :)
The following user(s) Liked this: caprinut, stingray-63, Al, silvertriple, jord001
My M chassis builds 2 years 4 months ago #69522
Wheels all trimmed back & ready for primer ... I don't know if the weather is going to be up to  between now & Christmas, I might end up mixing some Gun Metal & Flat Aluminium & using that over the bare plastic instead :blink:
I've collected some bloo bits (including the rubber shielded bearings) for the build.
This is a slightly better representation of the body colour :)
The following user(s) Liked this: caprinut, stingray-63, Al, jord001, Ducksnuts
My M chassis builds 2 years 4 months ago #69644
11 degrees C, and 90% humidity is not ideal for spraying, but it's the best it's been for a long while, and might be as good as it gets before Christmas, so I got some grey primer on the wheels :)
My M chassis builds 2 years 4 months ago #69849
Last touches on the wheels - 4 light coats of Titanium Silver airbrushed on, and two coats of Rubber Black brush painted on the edges :)
My M chassis builds 2 years 4 months ago #69939
This is pretty much finished, bar getting some pretty, final pics.
One thing I did find though, the M-05 chassis was weirdly unlike those I'd built recently...  still obviously a Tamiya M, but oddly different.
Then I remembered, the last 3 M chassis I built were all M-06s :whistle:
My M chassis builds 2 years 4 months ago #69945
Various steps in building the chassis:
My M chassis builds 2 years 4 months ago #69946
I like the m05 because you don't need any spares to have the 3 wheelebases. And it is compact.
Time to create page: 0.220 seconds
