Re: Williams FW14 resto 11 years 10 months ago #10765
It looks as run on carpet/indoor, and had the motor replaced recently to relive memories?
Last edit: by larbut.
Re: Williams FW14 resto 11 years 10 months ago #10768
My helmet is peeling and crusty :whistle:
your ears need a shave :evil:
Re: Williams FW11 resto 11 years 9 months ago #11289
Been working on the helmet ...
Stripped of paint:
Filler:
Sanded & primed:
Paint:
Re: Williams FW11 resto 11 years 9 months ago #11290
Made my own transfers to replace the really manky ones:
... but they just didn't work on the helemt ...
... so on to plan B - making my own vinyl stickers: printed out & stuck on the back of the vinyl:
Cut out:
... & stuck on - a bit of warming up & bending pressing down required I think :
Re: Williams FW11 resto 11 years 9 months ago #11291
I stripped the chassis yesterday, the two halves had been glued together with evostick - I've scraped the subchassis here, but the (black) chassis is yet to be done in this photo@
Bits that were small enough to go in the tank produced this dirty water:
... & this crud in the bottom of the tank:
I wouldn't mind so much but that all came from these few bits :S :
The edges of the GRP bits was holding a bit of dirt, so I sanded the edges:
... and sealed them with X-22 Clear:
Re: Williams FW11 resto 11 years 9 months ago #11295
Funny the avante 2001 im going to rebuild has the same problem around the edges of the chassis i may try sanding back like you have and clear coating it too. on the avante 2011 it tells you during the build to seal the edges with glue would this obtain the same finish?
Re: Williams FW11 resto 11 years 9 months ago #11299
I've seen superglue suggested, but I've used clear on a couple of Scorcher chassis & vintage Sand Rover/Holiday Buggy rear "springs", so stuck (pardon pun) with that :)
Re: Williams FW11 resto 11 years 9 months ago #11310
A few more details ...
The wheels had about 3mm protruding on the inside, so some very gentle work with a scalpel followed by sanding saw that off ... I suppose I should have done a bit of research to check what width the tyres should be, but chances are I'll never have to put a new set of tyres on ...
The antenna was missing, but I have a spare used one ... before:
... and after sanding/treating with Bilt Hamber "Hydrate 80" rust killer:
I don't have a "before" pic, but this is the underside of the chassis after sanding & waxing:
Re: Williams FW11 resto 11 years 9 months ago #11336
Got on with building the chassis last night ...
Getting a head start on "gluing" the chassis:
Step 1 (gluing the tyres) was already done, step 2 (gluing the chassis) I'd already done, step 3 was starting the motor pod:
Step 4 was trimming, painting & fitting the undercowl - obviously the trimming was already done, but I'd put a second coat of black on ... Step 5 was assembling the rear axle & diff:
Step 6 was fitting the axle, step 7 fitting the motor, step 7 assembling the top of the motor cage:
Step 9 (fitting the battery straps), 10 ("chassis stay") & 11 (top of the battery cage & standoffs):
Steps 12, 13 & 14 were building & fitting the rear shock:
Re: Williams FW11 resto 11 years 9 months ago #11337
Steps 15 & 16 - front wing/suspension:
Steps 17 & 18 - fitting front end & zeroing servo:
Steps 19, 20 & 21 - steering servo:
Steps 22 & 23 - ESC & RX, antenna:
Steps 24 (steering & chassis roll adjustment) & 25 (wheels):
Quick test - hope they hoover out :whistle:
Time to create page: 0.254 seconds
