Yes i thought that was a little strange too probabaly wont re-use the technigold if anyone has any of the bits i need ill trade it out if you can use it i have spun it up with a battery and it sounds good |
IDK about the MB, but that's definitely in the manual for some other cars (Lunchbox, etc?) to stop the motor wires getting caught up in big rear tyres |
Thought id dig out the de-solv-it grafitti remover tonight as i was bored two hours and three coats later between tea breaks:
i have found it also desolves glue (from around the sunroof mounting) came off like rubber afterwards which has saved me a job ordered some re release rear arms tonight slowly picking up the bits i need but the J parts i need seem quite hard to find so it looks like it will need to be a used set which can be risky as it seems they are prone in this area probably end up buying another cracked set Checked the manual but it doesnt show cable tieing the motor wires down anywhere in it |
Last edit: by tamiya nut.
I need de-solv-it grafitti . very nice body
seriously good stuff cannot rate it high enough so easy no work involved
Looking at the body again tonight wanted to repair two small hairline cracks in the circled areas where the impact has transferred from the nose cone through to the shell. I have ordered a blitzer nose cone as the original was too far gone. Any suggestions on what glue i should be using on this epoxy resin doesnt seem to be working well it keeps seperating?
Cheers |
I might be interested in your old Beetle nose cose for my Scorcher. I think it is going to be "rat look", so condition is not so important. Might be able to swap for something?
Last edit: by Martin Bell.
by too far gone i mean it had a crack that ran from the side under both headlights and stopped like an inch from the other side it was nearly in two pieces really badly damaged. i had to cut it to remove the licence plate for my new one..sorry
I use regular plastic kit poly glue, like this:
