Time at last for the MCI decals, and see if the red painted areas had the desired effect around the CUSTOM 150 lettering on the wings, personally I’m I’m quite happy with the end result, if I was to redo it again the only thing I would change would be using white primer under the red area as it could do with being a slightly brighter red
You will have to excuse the roof, it can’t be seen in a box art pose, so I took liberties haha
Last edit: by goldfish999.
Perfect my friend. I love it.
Came out very well |
Well I can’t put it off any more, the scary part of painting the grill boxart, many thanks to Jonny for his post the other day mentioning Kyosho 0.7mm tape and 3M 3mm tape, I purchased both straight away haha, so it took a bit longer than expected but finally have the grill masked up, I just hope the paint job matches how good the masking looks
I've never used the Kyosho tape for masking, only for pinstriping/edging, so I'd be interested in seeing how it holds up
The only masking I've done on Blackfoot/Ranger type grilles was for the body colour strip above the bumper - even then I've only done it once, on my RV, comparing that with not doing it on my fake Ranger, I probably ought to pull it apart and do it as it does look better done. Black bits I've only ever done with a brush. This looks pretty ambitious - good luck with it |
The kyosho pinstripe did ok in a fashion, I think if it was on a flat surface you would get a lot of feathering under it and not a straight line as the glue along the edge is weak and not regular enough As for the body line under the grill I had not noticed that before, so it’s back to some more masking up for that, not sure wether to say thank you or d@mn you Jonny
After a little bit more painting little bits and fitting windows it is done (well apart from Ronnie, I’m saving drivers for another day once my painting skills have matured a bit)
Hope you all enjoy the end result, I know I am very happy with it even tho not perfect by any means, but shaky hands and poor eyes limit me |
