Never thought about saggage over time, nice work Andy , what would you suggest, cut a little disc of lexan out place in hole and drop a blob of shoe glue on it? |
Last edit: by goldfish999.
Man! This chassis looks in a very nice state. Not a lot of runs.
While the front end is soaking in various potions n lotions, time to strip the rear gbox assembly down to components
And then take electrics and remaining plastics off the tub Rear end parts and tub etc off to the cleaning station(the sink ) and while everything is simmering away in the kitchen give the electrics a clean down with isopropyl 2hrs later and all parts are clean yayyyy
you are lucky the front upper deck supports aren't brocken. Be carefull to not tight these scrws too much.
Look at the state of the ally gear in the rear gearbox. And try ro replace it by a ta02 one if you want run it. What is isopropyl? |
Isopropyl alcohol, a great cleaner on electrical items, as it evaporates very quickly, and as a bonus you can also use it to thin down acrylic paint for airbrush work
Thanks a lot my friend.
A little disc is a great idea and maybe use some body reinforcing tape to secure them If you can't fix it with a hammer, you've got an electrical problem mate
