You got a good point there. Can't imagine it was done purposely... If the ball diff was left in the rear gearbox then that's just wasteful and lazy. Don't get me going there, Jonny! Getting an alu idler to TN (the TS) wouldn't be a problem. Got one of those for him - and waterbok would even have a gear shaft and the caps with it. But since the car will be taken all apart, I'd invest a bit of budget in a new 50529 gear set with the plastic idler. And also replace the other gears in the process... Tamiya nut would only need a shaft for the idler in addition then. Dang, I'm getting curious about the idler evolution. I know the gear diff was used in (many) many models and a TA03 ball diff and one way bearing would even fit this car... |
Think you might be correct JR when you mention the 'conversion' its probably been knackered somewhere down the line and they have just removed it completely.
Waterbok i could definitely use the shaft and end caps you have if thats ok as i dont want to have to buy a parts bag and tree just for these two small parts if nobody has an idler gear ill order this in from feebay. I thought the same about the spur gear but i have inspected it and it looks ok? Paintjob is bad but hopefully ill have this off soon but annoyingly someone has cut the headlights out of the shell for some strange reason and they have done it badly. Im hoping to reuse this body so ill try everything to recycle it. |
looks similar to what's lurking in the TL01 gearbox to me.... Got 3 spare sets of TL01 gears & another partial set from something that might well be TA02 (Seem to remember something in the instruction sheet saying like "If it's 2-piece, use this bit instead")- I'll try & get in the loft tomorrow to check the part numbers on the bags (You may have to remind me)
Thanks Eddrick that would be great
The TA01/TA02s share a few components with the TL-01...
Don't know all the details but it looks like when it comes to the gears only the diff matches. I was hoping the idler also but that seems to have a larger diameter since it uses 1150 bearings instead of 850s. Shared components are more in the line of suspension (and it's propulsion) parts... Keep us updated if any of eddrick's gears match though. |
Had a dig about, this is what I've got (Other than TL stuff) - Looks like the gear you want is there & the shaft caps. If you still want it, let me have your address & I'll get it off to you. If you let me know the diameter & length of the shaft (I'm assuming you still need that too?) I'll have a dig about & see what I've got, or I'll make you one
The following user(s) Liked this: tamiya nut
PM my address to you eddrick thanks for all the help with this guys im going to order a bearing set now and ill post the clean up and rebuild once i have received all the bits.
Shaft is 5x19mm thanks Edou This is a great website for picking up random parts required for rebuilds and the knowledge base is awesome |
He Edou, thats something for your Manta Ray ridlles.
This SP529 gearset on Eddricks picture looks to be the second edition (9005355) gearset (for top force) where you only would need the alu drivegear. (3545007) The first edition (9005322)should be the one where you have both idler and drivegear (9805373) made out of aluminium. Third and final edition would be all gears made of plastic. (now 50529) the numbers between () are the current parts numbers I found at Seidels. The gear at bottom right seems to be out of place. The Idler gear should measure approx 14.4mm diam. and 12.3mm wide Yep shaft is 5x19 |
Hehe. My kind of riddle... but I think something else might be going on here.
Seems to me that this is a 3rd generation set. 50529 comes with both a gear diff and ball diff housing. Like on the picture above. But the biggest clue - 9005355 and 3545007 don't have the small ball retainer for the thrust bearing on it. And eddrick's sprue does... The gear that's out of place is a TL-02 spur I think, while the one for a TA02 is missing. Even Seidel recommends to go all plastic while you're at it btw. |
