I think that Jonny did something like that.
a micro servo mixed with the steering servo should work.
I need to think, adding a servo might be a way, but not sure this is the way to go, as there is not much room there. That being said, the steering servo is not very far, it pushes to go right and pulling to go left... adding a cam under the body on on the left side of the helmet may just do what is needed. Only diffculty is to find the way to fix this and to transmit it thru the body...
Need to think more That's in mind since I started to mount this buggy... I buy kits to built and ru(i)n them
Tonight, while the sun was going down, I ran the Turbo Scorpion on the garden track... This track seems to work well, but I need to find a way to add some ramps and jumps....
For the small story, the hay collection works very much better with the Super Hotshot than with the Kyoshos... ... And in the case of the Turbo Scorpion, at the first pull on the trigger, the hay goes off :-D I finished by a quick clean up after a photo shoot at sunset time. The clean up did not took long... Looking at the rear side, I'm considering changing the way to fix the rear led lights to do something allowing to fix the leds without bucket lights in the same spirit than what I did with the Super Hotshot... I probably need to think more... I buy kits to built and ru(i)n them
The time I implemented red leds, I know I would do something else at some point. The time has come. It took me about one hour of CAD work and two prints to get it right .
I designed it in the same spirit than what I did for the Super Hotshot. The part is fixed using a M3*12 metric screw. Parts is available here : TurboScorpion Rear led lights holder by silvertriple - Thingiverse I buy kits to built and ru(i)n them
It's very nice! And the licence plate is awesome.
The license plate comes from Tamico.de where they propose custom ones... As I like to have a car which is my own one, I thought it was perfect to finish the car...
Yes the perfect final touch.
