Had trouble with the styrene tube I'd used for the rollcage - as usual Poly glue, superglue & Araldite just didn't work, and even Plastic Weld (Dichloromethane) wasn't up to the job of having the interior wiggled into the shell ... in the end I used strips of cotton cloth & epoxy resin as reinforcement - hopefully it'll just look like padding when everything is painted; oil cooler & fuel tank also added:
Added a filler neck to the fuel tank: ... and air horns: |
same the horn pipes
Finished all the aerosol work:
VW Alpine White on the body, roof # plate & lower exhaust Clear on body & roof # plate Satin black on tonneau, front license plate, top 1/2 of exhaust, window nets (really not convinced by those) VW Mars Red on the "fire extinguisher" "Chrome" on back 1/2s of lights "AA Van Yellow" on front 1/2s of lights The plan now is to concentrate on getting as much spraying in on other projects as possible before the weather turns (several driver figures, Blackfoot, Wild Willys IIRC). |
When comes the built? It is so realistic. I would like to do a like level model.
I am crazy by your fast and quality work. Jonny you are an ARTIST |
Do you use a paint cabin?
I have no painting facilities at all, I spray bits outside.
Paint for my Wild Willys failed to turn up so I started the detail painting sooner than expected...
Not so much on the interior as lots of layers need doing: Drivers: - base colour for driver suits was 2/3 XF-3 Flat Yellow, 1/3 XF-4 Yellow Green, - highlights 2/3 XF-2 Flat White, 1/3 above yellow mix, - lowlights 9 drops above yellow + 1 drop XF-68 NATO Brown - wash = 9 drops above yellow + 1 drop XF-52 Flat Earth + 3 drops water Dash: - base colour: 3ml X2 White + 1 drop X-9 Brown - Radio: XF-69 NATO Black - details: X-11 Chrome Silver (still need to make clocks/gauges) Oil cooler: X10 Gun Metal, X-11 Chrome Silver Fuel tank: XF-9 Hull Red, XF-69 Rubber Black, XF-16 Flat Aluminum (sic) Exterior on the other hand is basically done, though I still need to make a shorter front body post & make holes for it: Door window apertures & tonneau: XF-69 Rubber Black; Door handles & front license plate back: XF-69 NATO Black; Front indicators: X-26 Clear Orange; Sun Visor: XF-56 Metallic Grey, edge with black 0.7mm Kyosho Micron line tape; Air Horns: X-7 Red + X-11 Chrome Silver (masking was a little tricky): Left sill (supposed to be where chromed trim has fallen off revealing surface rust & dirt underneath): dry brushed Humbrol Acrylic #113 Rust + XF-69 NATO Black/water wash: Right sill (chrome still there): Aluminium foil tape: Rear Lights: XF-16 Flat Aluminum base, 3 coats X-27 Clear Red, Aluminium foil tape: Exhaust: XF-69 NATO Black, then X-22 Clear: |
AMAZING!!!!!!!!
