58034 Super Champ light resto 9 years 7 months ago #31034
Yes, that makes sense.
Front - 6mm
Rear - 4mm (RR/SS), 5mm (SC)
Since the MK1 arm is incorrect anyway - maybe get a couple of Buggy Champ arms and drill them to the correct size?
I'd also have to drill & tap for the extra M3 holes & remove the bump stops, doing that (plus the cost) doesn't look that attractive compared to making a couple of collars, which is just one more step and "free", other than time.
... BTW - How's this "light" restoration working out for you? :pinch: (You gotta laugh or else you'll cry :) )
Still cheaper than buying an NIB one ... though not a re-re one. Or two. :whistle:
58034 Super Champ light resto 9 years 7 months ago #31038
& on that note - my 6 NOS ball ends arrived ... mmmm, expensive :blink:
58034 Super Champ light resto 9 years 7 months ago #31065
0.5mm Glace cotton thread (note price in Rupees), woven & superglued into window netting, I'll give it a puff over with satin black later):
Machining rear arm spacers from 1/4" al. bar was a little fiddly:
Body details painted:
I know I still need to clean up the round aluminium parts, but after that I think it's probably just a case of needing to make sure I have the right fasteners & nothing else is missing, then i can start putting it together.
Actually no I can't, I have to make some servo blocks....
58034 Super Champ light resto 9 years 7 months ago #31108
NOS tie rods, homemade steering rod, servo mount blocks, shock spacers & battery post :)
58034 Super Champ light resto 9 years 7 months ago #31111
Window netting is heavier than original, but still better than the stuff sold on eBay :whistle:
Overall I'm very pleased with it, especially the paint - it just looks dark blue at a distance, but close up there's a hint of rich purpleyness & sparkliness :D
The following user(s) Liked this: tamiya nut, Edou, stingray-63, AndyAus
58034 Super Champ light resto 9 years 7 months ago #31128
Spotted some Pargu one piece Scorcher "Type B" wheels on eBay ...
... Which meant the original ones were surplus to requirements ...
... so after a bit of raiding the spares box & mental juggling ...
... Froggy got an upgrade, the new wheels got correctly shod, and the spares box got a downgrade, but who cares:
Starting on the chassis build, not quite following the manual steps exactly ...
... and a bit more:
This photo is more of a mental place holder for me than one that can impart any useful info (I blame the autofocus sensor being so off to one side that unless the subject is in the top right corner, it doesn't get focussed on :whistle: ) - the m3 threads on the two left side front arms stripped. This never happens when you're dismantling or checking the threads, only at reassembly ... the end around one hole has crumbled & the thread rung off, the other developed a bit of a crack & felt like it was on the cusp of stripping but not quite torqued up enough - I turned the hex driver a tiny bit further & stripped that one too :huh:
58034 Super Champ light resto 9 years 7 months ago #31130
I carefully drilled out the remainder of the thread with a 3mm drill bit, then enlarged the holes with 3.2 and 3.5mm bits, tapped the hole with #2 & bottoming M4 taps:
Had to use overly long grub screws temporarily as I'd run out of the shorter ones :blush:
That's torn it .. I have to say I feel ambivalent about opening this - in less than two minutes I took off 80% (I guess) of it's value, going from NIP to unused to used ... on the other hand, it's a spare part - keeping it in a box & looking at it occassionally, then putting it back because it's "too valuable to use" was daft..
Front end competed:
... and the rest of the chassis. It didn't seem worth putting radio gear in until I know what I'm going to do about the missing speed control.
And "done" for now. Yellow tinted oil bottle was a deliberate choice, My memory may well be faulty but I remember ALL old Tamiya kits having "yellow" oil, so the "correct" blue bottle just didn't look right to me :)
The following user(s) Liked this: Manotas, stingray-63, AndyAus, Al
58034 Super Champ light resto 9 years 7 months ago #31131
I hate it when that happens :cry: I have a stash of SRB front (and rear) arms with stripped threads, optimistically waiting for someone to come up with a miracle fix with some sort of filling that is strong enough to make new threads :blush:
58034 Super Champ light resto 9 years 7 months ago #31132
You're really dead set against using the next size up? I know the two I used are sticking out, but hose are M4x6mm, the shorter (shortest) M4x4mm aren't quite so offensive ;)
58034 Super Champ light resto 9 years 7 months ago #31134
I actually drilled new holes on a couple of arms, to be used on a runner.
Time to create page: 0.235 seconds
