What a super job you've done, that's the best 'tidied up job I've seen in a while.
With the front arms, did you consider putting helicoils in? I hope you had the old yellow 'shock' bottle x rayed and crack tested, we all know how much pressure is in a shocky reservour. Great job, I look forward to your next tidy up job. |
Last edit: by larbut. Reason: finished that end-quote tag
Well that's devalued it, not only have I taken the NIB Mk.II Acoms set out of the box, I've fitted it, and USED it
No balloons (or "waterproof bags" ) as I've had some bad experiences with them rotting on shelved cars recently... Still need to source an MSC ... Switch boot needs some trimming, according to the manual... Glued on, fake AA cells fitted: |
Jonny if you want I have 1 of this type of MSC if you want. I don't have the need of it. |
Thanks Stingray, but after running a "wanted" add & asking several times, I bought that NIB on eBay |
Mine is in the same state. It was sold with oxydation. I though that it was used...
You'll probably have a heart attack when I tell you I chucked one of them out about 3 weeks ago.
I'd had it for about 25 years and had forgot what it was out of. Couldn't find what it fitted with a 5 minute google search, so it got binned. I think it was used, I did have a Super Champ when they were new. |
