Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46500
Dude buddy. I love these rims. And tires sound very good. They stick to this dragster rod style. :y:
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46501
Now this is very cool buddy B)
Last edit: by AndyAus.
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46502
  • frog66
  • frog66's Avatar Topic Author
  • Born to be Wild
  • Born to be Wild
Thanks to stingray and andyaus.
The next work will concern the completion of electronics and all the modeling detail.
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46553
  • frog66
  • Born to be Wild
  • Born to be Wild
Brake pump
Speed regulator
The following user(s) Liked this: oldwilly, VCR
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46554
Nice Frog.
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46620
What you've done there is stop at the first kludge that worked and called it a "solution" :whistle:
Is this the right place to post such a comment ?
You know, I still think it is ... or at least better than after that exposed servo horn has got ripped off (or the internal gears broken) by an errant stone & the finished car slams into a kerb ...
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46622
Excellent work on the the brake servo - is the body vacformed or carved from solid?
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46629
  • frog66
  • Born to be Wild
  • Born to be Wild
Jonny the body is vacformed,most ligthweight.
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46643
Hey that's turning out to be quite a hot rod, nice work on the brake master. :y:
Where did you get the bolt heads I see on it and the nice looking engine mounts?? Are they from Tichy ??
And with your vac forming skills perhaps the could be a nice streamlined cover for that steering servo horn?? hmmm??
Keep up the great work!! :)
Sand Scorcher MK 1 Hot Rod 6 years 5 months ago #46645
  • frog66
  • Born to be Wild
  • Born to be Wild
Thank you.
The bolts heads are from Meng Models.
I see the steering servo worries several people.
All right, I will create a protective dome, even as I have written the car can only run on carpet or palquet.
The tires are not suitable for road use.
Time to create page: 0.258 seconds
