For remind, the grasshopper1 has the same front as the lunch. My rere montero has bigger sterring shaft than originals. They looks like TA ones. Bigger and harder. Same the junction balls.
I'm using carbon reinforced F103 knuckles (same as Grasshopper) with 5mm ball ends in it.
![]() Servo horn #? - I got to 17.5mm since I was limited to certain offset dimensions : Apparently that is still a bit too much for the left suspension arm. ![]() Next, using the other hole in the knuckle (and tweak the horn a bit more)... |
That turned out to be the last detail to make the setup work. Going from 5mm to 4mm. ![]() Final version of the servo horn (smaller still and a one-piece FRP spacer) : Installed : Larger view : Just fits : ![]() |
Nice one
![]() ![]() ![]() If you can't fix it with a hammer, you've got an electrical problem mate
Last edit: by AndyAus.
Wow.. That looks great!!
![]() ![]() Current Project:
The Dylan Project Grasshopper
My Projects in the works: The Fighting Frog, The Restoration of my Fox, Back in the Day Blackfoot Racer, The JRX-2's, Yokomo YZ-10's of fury x3 I'm not a Re-re yet!
