"Water Dipping" is a valid way of speeding up the process of bedding the brushes in, if you're a racer & are also making lots & lots of other tiny incremental changes ... I wouldn't suggest it as a cleaning method though. |
Sorry Jonny my English is not very easy to understand
I wanted to say: put the motor in a recipient full of water and power it in the water. A friend did that and give a second life to an old 540. It is a cheap method to clean the motor. It is efficient and this method was used in the 80's to "roder" (in french) the new motors in compétitions. |
Volume could be loud :
Yes, but triggered by the motor drawing too much current. Trouble shooting electronics can certainly be tricky stuff... |
Thank you Edo for the demo exactly what I want to say
steering problems
Blimey oh Riley! I'd never have thought of sticking an electric motor in water! That just sounds so utterly wrong..... I'll swap out the motor and see if the next Technigold eliminates the problem - ifso, I know I've got a motor that needs something doing to it! I think I'll crack on with the drilling of the rubber boots too unless there's a better suggestion to cure the steering issue? |
Last edit: by rjsdavis.
I've actually mailed the guys at LRP about this beforehand.
They said it was a good idea with 3V and demineralised water... It was a nice experiment but now I'd rather do a dry running in (at low voltage) : Next time I'll make a better contraption with a motor heat sink. That one has a chip on it so submerging it would probably not be a good idea anyway. |
unmineralised water or alcohol are good to avoid minerals deposits and they have no charged elements. For the alcohol, not enough oxygen to explose. disgreasing too.
For your throttle cuts, I think that it comes from the copper wires wich lost the varnish protection. and with the heat make short cut. The low voltage power submerged makes the heat up lower |
Last edit: by stingray-63.
