I did not show it here, but I actually sanded down the glue on the outside of the tyres, as that was quite simple, sanding down the rim at the same time.
But, sanding the inside just looked to complicated and time consuming to be worth it. If I only had a lathe... ![]() Maybe a cordless drill, coarse sandpaper, a steady hand (and a vacuum cleaner) could do the trick? I'll give it a go if I find the time. ![]() Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
It came with the car, yes. The complete MSC was actually very nice. ![]() I'll have a look if I have one of those arms for you. Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
Last edit: by larbut.
I never had to remove glue on foam tires but maybe with sand paper??? Very lightly ???
Is this something you can use, Andy? No wires, and used.. but the best I have ![]() Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
That would be absolutely perfect ![]() If you can't fix it with a hammer, you've got an electrical problem mate
Before (note the damaged edges) : And after letting it turn with a piece of sandpaper pressed on : ![]() Best to take it step by step so it doesn't overheat (which will make the foam slightly melt and deform).
Nice work Edou
Thanks, restored them a while back but they really did turn out nicely. Together with some WD-40 I used (this acts like gripper and cleaner on foams but I'm not sure it's recommended for a shelfer) it totally smelt like a tropical island here.
Nice, Edou!
The Wizard's rims inner edge being wider than the foam will complicate the procedure a bit, but, I'll have a go at it ![]() Signature now gets correct formatting if you edit it in your Profile. Use normal BBcode if you want.
