Richard's adventure in scale garage and related items. 1 month 3 weeks ago #75917
Very impressive Richard!
Richard's adventure in scale garage and related items. 1 month 3 weeks ago #75934
Thanky you very much chaps!
Yesterday was a day of failures.
Micro on/off switch was either melted due the solder heat or it got super glued together.
Only thing I got done was planning the negative power wire.
And the positive power wire which will run on the underside..
Then it occurred to me I can make a maintaince free on off switch by using a standard male servo plug and make a jumper for the end
Todays progress was awesome if I may say so myself!
I completed all the power system for the lights.
System is 3v and each 1.8mm led is running of one 47ohm resistor.
Like so
Underside
My on/off switch aka servo plug was hidden here
And first test. Exactly how I wanted the lights to be!
Wires painted. Makes them look less messy. I ledt the rear section bare as I still have taillights to install when the sides are mounted
Power off
Power on
And then into my scale garage, while other bits is getting made / painted.
The following user(s) Liked this: stingray-63, Al, 1972 LeMansGT Jim, Ducksnuts, EddyCH
Richard's adventure in scale garage and related items. 1 month 3 weeks ago #75937
Wahoo that's crazy Richard. I love these lights.
The following user(s) Liked this: caprinut, Al, 1972 LeMansGT Jim
Richard's adventure in scale garage and related items. 3 weeks 4 days ago #76338
Today I made the other side panel for the trailer.
A bit testing
To make it finish I need:
#Make holes for the upper front ramp rams.
#Make the front upper ramps.
#Make the track and "bucket" for the rear part of the front upper ramps.
#Paint the inside of side panels black.
#Paint the outside of side panels blue.
#Paint the tracks.
#Assembly of trailer.
#Make the rear lights.
Still a bit to go, but getting there
The following user(s) Liked this: stingray-63, Al, 1972 LeMansGT Jim, Ducksnuts, GToddC5
Richard's adventure in scale garage and related items. 3 weeks 4 days ago #76340
I l o v e it.
Richard's adventure in scale garage and related items. 1 week 4 days ago #76617
Time to plan the scale remotes.
My transmitter of choice is the Attack R.
I just love all the angles. It's not as flat as you might think
Got most of the needed measurements down
All I had energy for today was to draw this.
