My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20033
can you make a sketch with dimensions of the bumper, would love to make me a rere of that.
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20166
I'm after more dimensions - forgot to ask about "j5" - the aluminium bits in the front wheels ... manual listing describes these as "10mm x 5 Aluminum Collar" ... I guess 10mm is the OD, 5mm the ID ... or the thickness?
:huh:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20169
OD: 10 ID: 4 TH: 5 B)
the screws (c4) are the same as in the M38 plastic spare wheel
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20170
Ta :)
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20186
Still no chance of spraying anything, thanks to more snow ... nothing is anywhere near complete, but I needed to unload my camera before I forget what's what :whistle:
The M38 body that came with the Wheeler is better than the one on my Wild Willy, so it'll get swapped eventually ... in the mean time, I need to repaint the loose bits - which means stripping of the muck that was already there. Paint on the driver came off easily, spare wheel took more as it was on very thick, the jerrycan I suspect had 2K paint on it :sick:
I've always felt the open backed jerrycan was naff, so thought I'd fill it in with styrene sheet before filling & sanding back (along with all the gaps on the other bits):
Tyres & switch boot are busy soaking in glycerine:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20187
Broken rollcage side bar has been fixed with M3 studding & Araldite...
Body is ready for paint ...
... and the wheels are ready for primer:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20197
Top work JR :)
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20471
Rollbar as arrived from waterbok ... if anyone is planning to do the same thing please make sure that the sprue you buy definitely has this bit on - the sprue from Siedel at least does not...
Drilled & tapped holes in the end as far round the bends as I dared, then superglued bits of M3 studding in...
If's amazing how bad something can look the first time you get some paint on it - I thought I'd get away with the marks on the uprights, but now they look like huge gouges ... pinholes etc on crossbar were all but invisible.
More filler...
Wheel spacers I made from styrene sheet...
Also painted the Wild Willy M38 driver body (and the spare I've had for a while) ... I'm thinking I'd rather have down the whole harness in red, as it is, black with the small red bits looks a bit too "Hermann Goering's dress uniform" for me :blink:
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 1 month ago #20473
funny, i got the rollbar on a sprue from Seidel. :huh: I got two of those from the first batches, maybe tamiya removed them later on. (the rollbar is not included with the Jimny and T2 shells)
My Wild Willy/Willy's Wheeler/Honda City Turbo Builds 11 years 4 weeks ago #20558
Masking the 1st M38 Helmet didn't work out that well, so I redid it freehand & tidied it up with Kyosho line tape...
Wheeler bodywork has had two coats of slightly off white (VW Alpine White) & still looks about the same in the photos :whistle:
Wheels have also have primer, off white colour & clear coats...
The "shelf" set I expected to turn out pretty well, but I'm pleased with the rescuing I did on the spare set :)
Before & after:
Time to create page: 0.529 seconds
