As I am charging my high quality 5000mah battery, I am examining and admiring the black rim wheels that I'm planning to use with my Volkswagen later. Then I suddenly see this; a hole in the tire! They all have holes, all these tires have these kind of holes in them.
Should I leave them open? Or should I glue them shut? When I press the tire I feel a stream of air in my face. |
Last edit: by uncletom.
keep holes. They permit to keep the pressure inside and the wheeles round. All my very used tires aren't cracked by these holes.
On rubber tires, that's a necessity. But now, generally, holes are in the rims.
The only car I have seen without any holes is the holiday buggy. My favourite that's on the lunchy series. When you press the tyre, I love the caracteristic pchiiiit. Holes are necessaries to avoid flat tires. |
Ok. But I cannot find any holes on the sand scorcher tires.
Oh, and I managed to off this little guy last night as my Hornet rolled over after I missed a curve on the skateboard ramp. I noticed him just fumbling around the wires, so I stopped the car and there he was up side down. Seems that the driver top fastening method isn't very reliable. And what can I do to prevent the battery lid to open? It wants to open frequently, after small jumps. I always have to check the lid at times to make sure its shut. Doesn't feel safe. Is there some easy hack? |
for the hornet you can use a rubber band. And the scorcher tires are grasshopper ones. You can make a small hole in the rim. Or nothing...
The following user(s) Liked this: blairis
