More progress, sticky stuff to start - internal window "rubbers" are self adhesive vinyl, as are the red & white warning stripes & mirror "glass". Tank markings are on clear waterslide transfer paper, grille badges are clear inkjet vinyl on metal tape.
I also had my first go with my Xmas airbrush kit - first with flat clear on the transfers & inkjet vinyl, then same on the window "glass" - front windscreen I masked first for the wiper cleared area, side & rear windows freehand round the edges. First attempt at colour too - paint mix was 2.5ml Orange, 2.5ml Flat Base, 5ml Flat White & 10ml Acrylic Thinners on both parts, but the tank was 15psi, close up & a lot of brush movement (so much the jar fell off at one point ), truck was 45psi, more distance & less movement & worked a lot better. Don't worry, I expected it to look bad at this point - it'll need at least one more coat of this shade, which is meant to look very faded & therefore has very little actual orange in it ... Cleanup wasn't too time consuming, though I can see now why so many how to videos feature a traditional fish bowl ... |
Too big to realistically go in the booth, I've been spraying outdoors (but undercover)
More progress, 2 coats of 1 part each Orange/Flat Base/Flat white, 2 more of 1pt:1:0, and 1 of 2:1:0.
This is the underside of the tank: ... & this is the top: Hopefully the fade gives a bit of a bleached look ... Overall the colour is much too bright IMO - I should have started with more white in the mix & finished at 50% white in hindsight, but it's too late now - hopefully the dirtying up process will tone it down a bit. Still a long way to go on the tank (detail colours, dirtying up, decals, sealing etc etc ...), even further of the cab (ditto + wood effect on the planking, arches, bumpers etc). I expect more empty pots along the way. |
I wasn't quite sure where to put this, it could equally have gone in the "interesting" thread as it's on eBay, the "How much" thread because it's overpriced (I'm pretty sure you could get everything new for the same price), or the "look at the state of that" thread because it's a lashup.
(for future reference: well used Bruder 1:16 Scania Garbage truck badly fitted to a Tamiya TT01 chassis, 200+ GBP BIN) However it's an interesting lashup - I'd previously discounted the cheap Bruder "conversion" parts on eBay as the subjects are too modern for my liking, I like building my own stuff, and not knowing how well they'd fit - looking at this, using a slightly narrower 1:10 chassis to start with & using offset wheels or spacer hubs, you could make something like this look pretty scale. |
a drifting trash truck
