That would be great, I'll pay for the shipping. The dimensions are perfect for the fuel cell. I'll try my hand at the highlift jack.
My Projects:
The fuel cell dimension of yours are perfect, don't worry about mine. The air filter i was thinking of is made out of foam, because it is covering the fan of the ESC. So i'm not too sure of the mounting method yet. My Projects:
Plans for the building of the highlift jack:
www.scalebuilde...php?t=1818 I'll be able to build this jack, just not too sure about the paint. My Projects:
My Projects:
Can't see the plan without registering & logging in |
That could work ... sort of a foam top hat I have some scrim foam I can try - I gues the height of the filter is 10-12mm? |
I'll send you the plan, PM me your email.
My Projects:
Another thing I was thinking of is a scale looking radiator and fan. Some of the truggies i've seen have a radiator somewhere in the cage at the back. I was thinking of using a small computer fan and making it spin. And piping it down the cage and to the front.
Anyway, just a thought. My mind runs away from me at times... My Projects:
Making it "functional" - i.e. fairly free flowing would complicate it, but it's doable, if rather fiddly ... I'm thinking a "front" & a "back" of lots of 2-3mm wide strips of 1.5mm sheet, spaced out by 1.5mm at the ends, sandwiching a bit of fine mesh, box in the top/bottom/ends, fake a cap & hose attachments, spray the whole thing sating black ... It's the kind of thing I'd have to "design" as I go - let me know some height/width dimensions if you want me to try Ps the jack looks good |
Just been looking at fans - they're less than
