Thanks. If I count my very first lexan body paintjobs, this Hornet should be the 7th body I painted.
Anyway. Maybe one day, I'll be able to do a perfect paint job (pictures are making it easier than it is in reality)... I buy kits to built and ru(i)n them
Hard bodies aren't so hard to paint. I did several the température is important.
Can't say why I'm a bit afraid by the paint on Hard body... I believe polycarbonate bodies finish is easier, as the body itslef will be the finish, while on a Hard Body, the finish is directly linked to the way you applied the paint... Maybe a question of being used to... And as regard to temperature, I paint outside even when weather is not good or cold. I generally heat the body shell with with a heat gun (the one I borrow from my wife's bathroom ), and sprays are store at inside temperature but I put them in a recipient with hot water (around 40° C). All of that ease the drying process (and I generally heat a bit the body again after paint application)...
That being said, the time I'll paint a hard body, I'll see how difficult it is..; I buy kits to built and ru(i)n them
Wich kit you'll buy before the lockdown ?
That being said, a part of the order is a bit on the dark side (because it is not all about Tamiya)...
Javelin? Super clod wrangler isuzu mu?
Tank? Truck?
Would love one or a Turbo Optima with a Javelin body... But none of those is available anywhere at the moment... That being said, there is no Kyosho in the next delivery (and Kyosho is definitely not on the dark side :-D) I buy kits to built and ru(i)n them
That will be a crawler? With a hard scale body?
