Re: 58087 Manta Ray 11 years 6 months ago #14706
Been working on the motor, it's pretty grotty - including some nasty soldering :sick:
Completely dismantled:
Re: 58087 Manta Ray 11 years 6 months ago #14707
Everything (apart from the bearings, which got a soak in oil) went in the ultrasonic tank for a good long buzz ... after that the manky wiring was desoldered, and ring terminals soldered on new wire as the correct tabs were missing :(
I was a bit skeptical about the need for the correct spring and brush spreading tools - but they were cheap enough so I thought I'd give them a try - the spring fitting tool in action:
... And the brush spreader - it's supposed to go in the other side (so you can get the rotor in) - this photo is just to show what it does:
Rotor in ...
... and the body & end cap:
Re: 58087 Manta Ray 11 years 6 months ago #14709
That should have been it - but after running it briefly it was obvious the bearing in the endbell must have been carrying some damage as it was getting hot very quickly - so it all had to come apart again for a replacement.
I've put new "Japanese" bullet connectors on the wires ... it still looks pretty rough, but at least i know it's clean & is going to run ok.
I'm not quite sure what to do with it now ... TBH I think it would be more at home in my Bigpg than in the Manta Ray ...
Re: 58087 Manta Ray 11 years 6 months ago #14710
Got a bit out of sequence, this is the rest of the lot & the issues I found dismantling it ...
Battery clamp is missing ... I wonder if we can convince eddrick to make a few? ;)
They're common to several cars - I also need one for an FF01 for a start ...
Never seen Hotshot tyres do this before - usually they just get rock hard ...
Manky shocks & rusty driveshafts...
Propshaft is very floppy ...
Front bumper, underside of the tub & lower suspension arms are all gouged...
TX seems to have been given a brush down but was still minging ...
Re: 58087 Manta Ray 11 years 6 months ago #14711
Body, wing & chassis tub got a scrub in the sink ... rx, servos, ESC & TX got a sponge bath, everything else went in the ultrasonic tank ... the only rebuilding I've done so far is the shocks:
I think that's pretty much all my updates across all my projects for now :)
Re: 58087 Manta Ray 11 years 6 months ago #14720
hehe. thats how my manta ray looked after two days on a Sicilian beach :cheer: :cheer:
did you rebuild the shock all in the same length?
btw looking at your pictures the car doesnt seem to be in a too much a bad shape.
Re: 58087 Manta Ray 11 years 6 months ago #14881
Got these in the post today (thanks for the tip Edou) :
Chassis tub after scrubbing:
And a closeup of the tub after lots of work with wet & dry paper & the Novus polishes:
Re: 58087 Manta Ray 11 years 6 months ago #14882
Looks very nice! I also used some Novus 123 in the past but found it quite expensive at the time. Don't know the prices atm. But its the good stuff :y:
Cheers, Bram
Restoring Countach 58005
Restoring 58015 RR
Restoring 58098 F40
Restoring Audi Quattro rally
Restoring Mk.1 Sand Scorcher
Restoring Porsche 936
Re: 58087 Manta Ray 11 years 6 months ago #14889
Nice! Definitely gonna try that stuff too... B)
Bram, a set of the 2 oz bottles (and some additional items) is about 15 euro with shipping. Directly from Novus.
It's shipping cost that kind of makes getting bigger ones uninteresting.
Re: 58087 Manta Ray 11 years 6 months ago #14896
Jonny, did you feel the need to use all three types or could maybe only the finest two be sufficient if sanded well enough?
Time to create page: 0.237 seconds
