58008 lp500s restoration 4 years 5 months ago #57547
Looking good Graeme.
The following user(s) Liked this: Graemevw77
58008 lp500s restoration 4 years 5 months ago #57557
Woohoo nice work on this countach. Is the aerial hole original? If yes leave it. If no, fill it. :p
58008 lp500s restoration 4 years 5 months ago #57560
Its not original as such, the body comes with no hole but 2 options. There was apparently a mark to make the hole where it is now, which lines up with the stock tube mount on the chassis. Or there is a plastic mount you could stick to the rear wing for some strange reason.
Every one that was built back in the day had to have one of those two holes made.
Last edit: by Graemevw77.
58008 lp500s restoration 4 years 5 months ago #57562
Thanks for the info. You have a third option used on vintage rc. You can roll the wire on a lexan rectangular sheet wich is glued with tape on chassis. And no aerial. ;)
58008 lp500s restoration 4 years 5 months ago #57563
Yeah, i did that on my 40th 934.
I plan to fit a 2.4ghz rx in the old futaba rx case so aerial is even less of an issue.
Its a 40 year old rc car though, cant help but feel they should have aerials.
As long as i decide before i prime it, i can repair it properly if needed. Ill sleep on it, but im inclined to leave the hole.
It will however be mostly a display model...
Im probably 75/25 in favour of aerial.
58008 lp500s restoration 4 years 5 months ago #57564
So leave the hole ;) . Period car period hole. :y:
58008 lp500s restoration 4 years 5 months ago #57565
Ive been looking at lots of 58005/8 pics and now im not so sure 😂
58008 lp500s restoration 4 years 5 months ago #57568
Well i guess thats that decision made :)
58008 lp500s restoration 4 years 5 months ago #57570
Yeahhh that's perfect :)
58008 lp500s restoration 4 years 5 months ago #57584
Time to create page: 0.176 seconds
