Just beautiful, the look brand new !
nice build to follow, great work!! Cheers, Bram Restoring Countach 58005
Re: the screw shoulders - have you got the proper washers on the steering knuckles as 'seats' for the shoulder screws? (They sit in the circular recesses top/bottom of the knuckles) - They need to be there as they sit proud of the knuckle, effectively extending the length of the shoulder. They also stop the shoulder crushing into the plastic & binding it all up. Would've done 8, but only had the 4 M6 buttons to hand.... Yes they could indeed resemble sex on a stick, but having never tried that, I can only agree with you.
Poor handling is what gives a vehicle 'character' - why else could the old kwak triples have been so popular?
One side did, the other didn't
Speed, and the delusion that owning one made you a Grand Prix rider? Can't believe they were worse than a CX though |
Just had a go at running up the motors with the MSC & the power/economy switch ... one of the motors - the rusty one - is ok, the other knocks like mad
The switch seems to have been rewired so "power" mode runs both motors in parrallel, "economy" just spins one I've worked out what I need to do to get it to work correctly, so a full rewire is on the cards once I get some green wire. I also priced up getting stainless fasteners for the rebuild, it came out at a couple of quid less than the truck cost .... so I think I'll be reusing the old ones. |
From memory, "Power" mode runs the motors in parallel, "Economy" runs them in series. If you have the switch to bits, you'll probably find one of its 'tracks' is pitted/burnt/dirty or the internal springy contact has stuck with heat/dirt - the 'knocking' might even turn out to be related to arcing in the switch.
Talk to 'King's Lynn nuts & bolts' for the stainless fasteners, I would've thought you could do the whole truck for less than a fiver.... (They'll post them too if you ask nicely) Trick to buying fasteners is ask what the minimum order charge/quantity is - 4x M3s can cost the same as 50x if you're not quick off the mark. It's also worth considering replacing self tappers with machine screws as they're easier/cheaper to come by. Also consider buying multiples of the longest fasteners & cutting them down, rather than 4 off those ones, 7 off those ones etc (Again to avoid minimum order/quantity costs)
The power/economy switch is working fine ... well, it was ... it sounded pretty unlikely, but I thought I'd check, so was investigating how to take it apart it when itexplosively dismantled itself- one of the wipers & one of the springs is gone forever The bits I could find, well, if you had a very small dinner, you could eat it off them Anyone got a spare? The motor knocking is definitely the bushings - I ran it straight off the battery & it sounds like the top end of a Ford "Zetec" engine at startup
Now that's stretching my credulity a bit too far - I make it 342 fasteners on the Bullhead, 5 GBP wouldn't even cover the 60 M3 flange nuts needed |
Hmmm i might have a spare switch laying around. Got a spare msc for the Clod i think.
Shall look into it tomorrow. Cheers, Bram Restoring Countach 58005
I think I have a spare MSC, resistor, and Power/economy switch. I'll zap it in the packet, and ship it tomorrow. Sorry about the delay, been hectic at work lately.
My Projects:
Bullhead Rebuild ... Ford F350 Mods ... Manta Ray Revival ... Custom Super Hornet Build ... TL-01 Crawler ... CC-01 Pick-up ... CR-01 With Hop ups ... Project Unknown ... Clod crew cab ... Other: Custom Display cases ... Limited Slip Diff(LSD) ...
Got a spare set of headlights for you aswell. Popped them in the packet too.
My Projects:
My Projects:
