Hi Jonny,
A TB member smitchos is selling some Bullhead parts tree etc if there any good to you? I bought his completed Bullhead off him after the re-build. Loving the Topic-Thread on this ![]() www.ebay.co.uk/...847wt_1270 GING |
Thanks Ging - I had a look, but the only part I need there is already on it's way from Louis ![]() |
![]() ![]() I did notice that the water temperature went from about 50 C to about 75C after several 8 minute cycles, so theorectically you might be able to boil hotdogs in it, eventually ... TBH though, I'm wondering what would happen if you put a can of pop in someone else's ultrasonic cleaner ![]() |
Capacity of that unit is very limited - claimed to be 750ml, it's more like 500ml ... you could get a CD in it, or something the size of a (185g) can of Tuna in there, but no chance of a whole chassis ![]() |
Apparently there are bigger capacity cleaners in the range - but the cost also goes up dramatically: Ultra 9000 - 5L tank 324 x 202 x 97mm, 250 GBP; Sonic 6000 , 5.5L tank 297mm x 147mm x 150mm, c. 400 GBP ![]() |
Bumper was even worse than the back end, so I sanded off all the chrome & details...
... patched it all over with styrene ... ... & filler: Note top side outer edge on the smoke stacks - I think this truck must have spend more time grinding along tarmac that it did on its wheels ... Capped the ends (styrene, with an M3 machine screw so I can fit some tips later: ... then some very thin sheet to hide all the damage: More filler on the tanks & the roll bar: Lots of sanding to do this afternoon ![]() |
